01-23-2019
13:42
13:05
01-23-2019
13:42
13:05
can't turn off exercise tracker. Started it when my exercise class started and can't turn it off.
Hey there @lfgray, it's nice to see you around here!
To end the workout, press the button again and tap Finish. Swipe up to see your workout summary.
For certain Fitbit devices, if you stop moving during the run or bike exercises—such as at a traffic light—your exercise pauses automatically while you’re still (known as auto-pause). You’ll feel your device vibrate indicating that activity tracking paused.
To continue, resume your run or bike ride; you’ll feel your device vibrate indicating that activity tracking continued. For runs, if your watch doesn’t detect a run for 10 consecutive minutes, you’ll see a message asking if you want to end the exercise.
To turn off auto-pause:
If you want to delete this activity that was tracked by mistake, see How do I edit or delete Fitbit data and activities?
Hope this helps, I'll be around if you need further assistance!
You're very welcome @lfgray!
If you're referring to the time spent during the activity, I'm afraid to say that there's no way to edit the time just the name of the activity. However, what you can do is delete the activity and manually log it with the correct details.
Just keep in mind that when manually logging activities, typically your steps will be recalculated if you manually log an activity as the manually logged activity takes precedence over the steps you tracked while wearing your tracker at that point in time. For example, if I am wearing my tracker and walking and I reach 10,000 steps, then I go to the computer and manually log an activity that starts and ends at that point in time for say 1 hour, Fitbit will calculate how many steps you took and it may bring my step count to something below 10,000 steps. To clarify, activities should only be manually logged when you forget to wear your Fitbit.
Let me know if you need further assistance!
Anytime @lfgray! ![]()
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best AnswerNothing is working to stop my fit bit’s exercise mode. I can get to the finish screen but no matter how I push the. Barge 3 screen it will not stop. This is brand new and my first time using.
Best AnswerWhen you press the button, it shows "paused", then you press again to get to an option page, and press finish. Next swipe to the bottom and press the "check mark". This should end the exercise... Hope this helps...
Best AnswerAre you pressing the play button??? Or the button on the side of the device???
Best AnswerYour welcome!!! Did it work???
Hey there @Kate_oa! As it has been mentioned, For certain Fitbit devices, if you stop moving during the run or bike exercises, your exercise pauses automatically while you’re still (known as auto-pause).
Also, with your Charge 3:
Thanks a lot for your help @T8B15!
I have tried this many times. It pauses and says press button to finish. When I press the button, it starts running again. I can't get out of the exercise mode. It kept running for several hours after my walk today. Have no idea how I managed to stop it. So frustrated. I am afraid to use it for swimming.
Best AnswerDirections are not clear on how to stop the exercise mode. Do you tap the triangle or the side button?
Best AnswerSame here - it's taken 10 minutes of me pressing the side button and play button on the screen to finally reach the screen showing finish option. Very frustrating! Once in pause setting it just starts playing again when you press the button - any tips?
Best AnswerI have been playing with it. Using it for my daily walk. It pauses when I stop moving. When I stop, I press the side button 2 times, quickly. That brings me to the "finish" menu.
