10-09-2020
10:00
16:17
10-09-2020
10:00
16:17
I can't find the way to turn off Charge 4 in order to save battery. Why a device like this doesn't have the simplest function to turn off? It is my first time to use Fitbit and it is utterly disappointing
10-09-2020 12:27 - edited 10-09-2020 12:28
to power off, connect charger, hold button firmly for about 8 secs and line will appear and grow across screen. when it stops, disconnect charger. it is off. To turn on, just connect charger and wait a few seconds. Note, if you have a bad lithium battery it will likely still drain even if powered off.
10-11-2020
07:47
07:59
10-11-2020
07:47
07:59
Welcome to the Community, @Kw046893 and @Kris227, thanks for the input.
I understand how are you feeling. I was able to see here that our friend @Kris227 provided information about your turn off inquiry. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
04-08-2021 14:28
04-08-2021 14:28
I was wanting to turn it off while riding a motorcycle so it will not count steps with the vibration. Do I need to carry a power supply and the charger in order to do this?
05-03-2021 18:05
05-03-2021 18:05
I tried the recommended method and it didn’t work. I put my Charge 4 in the plugged in charged, pressed end held the side button fir at least 8 seconds. No “line” formed across the screen; only the battery icon. After 8 seconds, the screen went black, then the “smiley face” appeared for a few seconds, and the Charge 4 was back on.
There has to be a better way to turn this thing off, do it doesn’t have to be charging all the time I’m not using it.
Thank you.
01-13-2022 06:52
01-13-2022 06:52
Unfortunately, as it says here (https://help.fitbit.com/articles/en_US/Help_article/1257.htm), if the device doesn't show up in the list (and Charge 4 does not), the device cannot be turned off.
01-13-2022 06:56
01-13-2022 06:56
01-13-2022 20:55
01-13-2022 20:55
I just decided to pack my Charge 4 up after use, continuous miscounts on my steps and calorie burn, I had enough. And the fact that you can’t then the device off makes it even worse. I’m returning mine back to where I bought it from and replaced it with a Series 7 apple watch. I guess you do get what you pay for…
04-04-2022 05:29
04-04-2022 05:29
Do u mean connect charger when charger is plugged in and turned on I have been told by fit bit to turn mine on and off today
04-04-2022 10:57
04-04-2022 10:57
The Charge 4 can not be turned off. The previous Charge 3 had this capability, but not the 4.
04-04-2022 12:59
04-04-2022 12:59
09-10-2022 13:10
09-10-2022 13:10
So we just have to let the battery die if not planning to use it for a while? Doesn't seem like that would be too good for the battery.
Oh well, I probably won't use it again anyway. Was just hoping to shut it down properly in case anyone else wants it.
12-06-2022 12:33
12-06-2022 12:33
Hello,
I read everywhere that I can not turn off Fitbit Charge 4.
The comment of Kris227 did not work, but I found out how it works (it works very similar to it):
1. Connect the charger to the bitbit chare 4 but do NOT connect the USB connector of the carge cable to a supply!
2. Press the botton and keep pressed
3. Connect the USB connector to a USB supply
4. At about 8 secs later a line will appear and grow across screen. when it reaches the end of the screen, release the botton and disconnect charger
Your Fitbit charge 4 is now turned off!
Turn it on again by connecting it to the cahrger (with is connected to USB supply)
01-26-2023 07:46
01-26-2023 07:46
I did that and it never shuts off. I just get the DND and SLEEP options
01-26-2023 09:41
01-26-2023 09:41
I described 4 steps to shut down Fitbit charge 4.
At which step do you fail?
02-20-2023 13:21
02-20-2023 13:21
I have also tried your steps Patrick and can't get it to shut down. I assume you're pressing the side button and not the bottom (typo in your message?). How long are you pressing for before plugging in? I've tried pressing for 8sec and plugging in, and pressing and plugging in straight away neither of them shut down the device. Are you sure you've got a charge 4? All other research suggests it can't be shut down.
02-20-2023 23:58
02-20-2023 23:58
Hello Mitch_f1,
sorry, yes, in step 2 you need to press the side button. This is not so easy because you have to press the side button through the hole in the charger.
I think I pressed the side button just a few seconds before I connected the charger to the supply.
I am sure that I had a Fitbit charge 4 (I already sold it).
That time I also thought that it is not possible to shut down this Fitbit, but I tried a lot an at the end it worked as I described it:
Turn it on again by connecting it to the charger (with is connected to USB supply)
03-07-2023 14:22
03-07-2023 14:22
What button? When I put it on the charger there are no buttons to push. the sides are covered by the charger.
03-07-2023 14:32
03-07-2023 14:32
At one side of the charger there is a hole. Connect the charger to the fit bit, so that this hole is at the psition of the side switch of the fit bit. It is a bit tricky to push the button through this hole in the charger, but it works!
03-07-2023 14:40
03-07-2023 14:40
Patrick,
Thank you for sharing your excellent tip with photos. It works as you described!
Snowman :snowman:
