06-04-2024
04:09
12:25
06-04-2024
04:09
12:25
It has been a while since I used my fitbit and everything has changed. Where do I go to update my charge 4 please.
Hello @Herbsahoy and welcome back to the Community. You don't say how long you've been away. Your Charge 4 might or might not have the current firmware and I will help you with that. The Fitbit app had a major design change last year and I will help you navigate through it to check your firmware. Tap on the icon in the upper left of your app, the one that looks like a mobile phone/watch/battery percentage. Now tap on your Charge 4 tile. If your firmware version is 1.100.76, then your Charge 4 is up to date and you don't need to do anything. If it is a different version, then you should get an update option in the next few days.
You can read more about the updated app design here: The redesigned Fitbit app is rolling out
Laurie | Maryland
Hi @Herbsahoy. Good to see you participating in the community.
Thank you for sharing the inquiry regarding your Charge 4.
I'd like to share with you the following help article: How do I update my Fitbit device?
If by any case you'd like to see this one too: How do I use the Fitbit app?
Thank you @LZeeW for helping.
@Herbsahoy, thank you for getting back.
Hope your device is going to get the update soon.
