09-22-2022 14:54 - last edited on 09-24-2022 08:08 by AndreaFitbit
How do I delete trackers from the Fitbit app?
Moderator edit: format.
09-23-2022 01:05
09-23-2022 01:05
Go into your account settings by selecting your profile picture on the main screen. Then select the device you want to delete and, finally, look for the "bin"
09-23-2022 01:05
09-23-2022 01:05
09-27-2022 01:18
09-27-2022 01:18
How to delete Fitbit trackers in the Fitbit app for Windows 10 Mobile
Launch the Fitbit app from the Start screen or from the applications list.
Tap the profile and settings tab on the bottom right of the screen.
Tap the device you'd like to delete from your account.
Regards,
Will
