04-05-2016
09:47
20:15
04-05-2016
09:47
20:15
My Charge HR was coming apart, so I got a replacement device. In order to avoid losing any data, I synced the data yesterday evening before removing the device, and setting up the new device (all using the latest version of the Android app).
Unfortunately, as soon as the new device was connected, my step count (and total distance) for the day was wiped out. Strangely, the floor count was retained, as were logged exercises and sleep (minus any periods of restless sleep)...
Is this a known issue that can be avoided, or just bad luck?
03-01-2019 00:45
03-01-2019 00:45
I had an Alta HR and upgraded to a Charge 3 today. I synced the Alta before replacing it with the Charge, and it looked like all the data had transferred over - except for my hours with more than 250 steps. The app is showing I scored 8 out of 9 hours today, but the Charge is only showing 3 of 9! It looks like the Charge is only registering the hours AFTER I replaced the Alta. I think I switched devices about 3pm, so I think the Charge is only registering the hours since then. As long as the app is right I don’t mind, but it will be interesting to see if the Charge correctly registers all the hours I do tomorrow.
03-01-2019 04:58
03-01-2019 04:58
MakMak | Community Council
04-04-2019 12:51
04-04-2019 12:51
11-15-2019 03:43
11-15-2019 03:43
If you had mobile tracker on your app you won’t lose anything
