09-08-2021
13:43
16:06
09-08-2021
13:43
16:06
How do I sync my charge 4 via fitbit dashboard on my laptop? Is it possible?
09-08-2021 13:49
09-08-2021 13:49
Hey there, @Antgirl3.
The Online Dashboard on the Fitbit's website is for you to check the data that was synced through the Fitbit app on your phone and it doesn't have the option to sync or setup a device. You can get more details on how to sync your Charge on this help article.
Thanks for stopping by, see you around!
09-08-2021 15:25 - edited 09-08-2021 15:38
While you can't setup the device using a Laptop, it is possible to sync with a Windows 10 laptop after the tracker has been setup using a compatible smartphone. You can then view the data in the dashboard using a web browser. I don't know if Apple laptops offer the same functionality.
Search for Fitbit in the Microsoft Store and install it. Login to the app using the same credentials you used to set the tracker up. I would post a link, but not sure if it's allowed.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
Best Answer09-09-2021 10:37
09-09-2021 10:37
@Antgirl3 If you choose to view your Fitbit data on your PC, you must know that the Fitbit app for Windows 10 hasn't been updated since 2019. There are some features that do not appear on the Fitbit app for Windows 10. The Sleep Score has been around for a while and is only available for Android/iPhone apps. Health metrics and stress management are mobile app features, too. I believe it is an unintentional quirk that devices can sync with a Windows 10 PC after setup.
@gdio53 Mac users need Fitbit Connect to sync. None of Fitbit's current (and some older) devices are compatible with Fitbit connect. There also seems to be a Bluetooth incompatibility between Fitbit Connect and Mac OS Catalina and Big Sur. This impacts users of older devices.
Laurie | Maryland
Best Answer12-03-2022 08:50
12-03-2022 08:50
I am beyond frustrated. I cannot sync my fitbit. Can't do it on computer. My phone is fine and does everything perfectly except it cannot connect after two years. What is going on!?!?!?!?!?!
Best Answer12-03-2022 14:22
12-03-2022 14:22
@KimberlyS246 You added on to an older thread. Fitbit deactivated the Fitbit app for Windows 10 and Fitbit Connect in October. You must use a compatible smartphone or tablet. Sorry about the frustration.
Laurie | Maryland
