09-01-2017
06:55
09:26
09-01-2017
06:55
09:26
Can anyone help me to track mileage on my Fitbit ? When I am done biking it says 0 for miles ?
Thanks for your help.
Moderator edit: updated subject for clarity and removed personal information
A warm welcome to the Fitbit Community @tekiral, hope you're doing great!
Are you using the connected GPS for your activities?
As you may know, Fitbit trackers calculate distance by multiplying your walking steps by your walking stride length and multiplying your running steps by your running stride length. By default, we calculate your stride length using your height and gender.
If you've already tracked one or more activities with the connected GPS, we evaluate that data to automatically update your running stride length. For best results, run at a comfortable pace for at least 10 minutes.
If your distance measurement seems inaccurate after double checking the above information, follow the steps below to calculate your stride length and then add it to your Fitbit account.
Your running stride can be calculated the same way if you run instead of walk.
To adjust your stride lengths using the Fitbit app, tap or click the Account icon and find the Stride Length setting.
Charge 2 work with the sensors on your nearby mobile device to track GPS data (known as connected GPS).
First-time setup:
Now, when you're ready for tracking your biking routine:
Syncing your tracker stores the workout in your exercise history. There you can find additional stats and see your route if you used connected GPS. ![]()
Give it a shot and let me know how it goes!
Best AnswerIf you are biking without using connected-GPS, Fitbit has no way to get distance.
Best AnswerHow do you get a gps?
Best Answerhow do you get gps
@Jeanerbugs13 wrote:how do you get gps
You would have to have your phone with you and use connected-GPS, whereby your tracker is connected to phone's GPS. I think it is on the Exercise Shortcuts screen, if you tap on Bike, it gives you the option to select connected-GPS. Then when you select to start 'Bike', watch and make sure it gets connected to GPS before you start.
I might not have those steps exactly right, not having Charge 2 right by me, but it is the general idea.
Best AnswerI have just about had it with my fitbit because it fails to properly track mileage on my bike ride. Essentially makes it an overpriced heart rate monitor. I have seen multiple suggestions on this site making sure gps is on for the phone; restart you fitbit; change the settings from auto identify exercise. One ride it will work the next two it will say 3 miles as it did today on a 25 mile ride. The map shows straight lines for routes but no mileage. My understanding its some sort of glitch they cant fix and hope you live with it.
