How to turn timer off on Charge 3?
ANSWERED
how do I turn the timer off?
1 BEST ANSWER
Accepted Solutions
@MelissaBaum  Are you trying to stop the timer or just trying to get to the timer function?
If you're trying to get to the timer function, simply swipe left on the Charge 3 screen and you'll see the "Timers" and "Alarms" screen.
If you're trying to stop a timer or clear it off your screen, you just need to tap the left button and then tap a few times to return to the home screen
Heather | Community Council | Eastern Shore, AL
29 REPLIES 29
Welcome on board @geenee57, it's nice to see you here!
Time events with the stopwatch:
  1. On your device, open the Timer app.
  2. If you used the timer previously, tap or swipe right to choose the stopwatch feature.
  3. Tap the play icon to start the stopwatch.
  4. Tap the pause icon to stop.
  5. Tap the reset icon to reset the stopwatch.
Keep track of elapsed time with the countdown timer:
  2. If you used the stopwatch previously, tap or swipe left to choose the hourglass icon.
  3. Tap the screen and then scroll to set the timer.
  4. Press the back button to return to the countdown screen.
  5. Tap the play icon to start. Your device flashes and vibrates when the time allotted is done.
  6. Tap the check mark icon or press the button to stop the alert.
Note that the stopwatch and timer can run at the same time.
Hope this helps, I'll be around if you need further assistance!
I am sure fitbit have made it much simpler to stop a paused timer instead of restarting it. How confusing. 👎
Update: OMG, not my day, trying to edit my reply and can I do it - No.
Meant to say Fitbit could have made it easier to stop a time. LOL
Welcome here @SunsetRunner, thanks for jumping in here! For anything else you would like to see implemented in the future, consider visiting our Feature Suggestions board. This is a space where Community users can post features, ideas, and suggestions that they'd like to see in future Fitbit products, accessories, and software and top-voted suggestions get relayed to our product team for review.
We're constantly striving to improve Fitbit products and services, and we very much appreciate all of the input we receive from our customers.
Our product team looks forward to reading and incorporating your suggestions into future versions of Fitbit trackers and apps.
Let me know if there's anything else I may assist you with.
Hi,
Your welcome email is appreciated. Thank you. I will take up the offer of making suggestions to make fitbit charge 3 the the first choice of fitness tracker for people. I am migrating from Vivosmart HR+ to fitbit charge 3, so can’t help comparing.
On the subject of the timer, where does it show on the dashboard ?
I am trying to use the timer function to monitor my indoor Rowing activity. My idea is to edit the timer activity and add indoor rowing.
So, if you can let me know where the timer is displayed on the dashboard, I’ll be grateful.
Kind regards
Gems1
Sent from my iPad
Thanks for getting back @SunsetRunner! The timer is not reflected on the Fitbit app. You can add this on our  Feature Suggestions board.
If you want to track Rowing, I'd recommend using the shortcut "Workout" and then you can change the name to "Rowing". Woman Very Happy
Hope this helps!
I understand how to stop the timer and reset it back to 0 s, but I can't remove the timer off of my fitbit screen ?  Any ideas out there ?
Welcome on board @DaveSnyds! There's no way to remove the Timer on your Charge 3 as you'd like to.
I am quite confused. When I tap the screen on my fitbit it doesn't allow me to go to the timer app, it just lets me scroll through the timed info such as heart rate,cals, fat burn, etc. I cannot get out of this area to stop the timer. I have the charge 3 special edition.
Thank you. 😀
Sent from my iPhone
Hello there @MelissaBaum , thanks for jumping in here! While reading your post I was wondering the same than @Heather-S. Is that what you're asking for? Smiley Very Happy If so, please follow her steps.
Additionally, I'd recommend taking a look at the following articles in case of doubt:
I'm glad to read that some of the steps provided along this thread helped you @SunsetRunner! Man Happy
We'll be around, keep us posted!
For those of you like me who were still baffled, to stop the timer / stopwatch you must:
1. Gently tap (not push) the left physical button.  If you push it, you'll be taken to another random menu that has nothing to do with the timer.
2. Gently tap (not push) the left physical button again.  (There is a scrolling tip that indicates this, but you generally can't read it before the screen turns off).  If you push it, you'll be taken to the same random menu.
3. Select the "Finish" icon in the upper part of the screen.
There are a lot of ways to mess this up, and this is the silliest UI design I've come across in a long time.
Not working,
There is no pause button on my watch. Just a clock with a rectangle inside and the timer keeps going. I keep tapping it and nothing is happening.
Thank you @JWinGB! I can finally turn off the timer. I've never started it intentionally, but seem to keep accidentally starting it. I agree with you on the UI. Not remotely intuitive.
I tried everything mentioned above and have read all the articles. My fitbit randomly started keeping time like a stopwatch, and I can't turn it off. I have lost my familiar looking home screen, and it won't seem to let me swipe left or right or top to bottom. When I tap the screen or the left button, it just goes through the clock, steps, calories, heart rate, etc... with that annoying timer continuing along the bottom of every screen. When I try holding the left button, I just get the screen showing screen wake and notification features. I can't swipe anywhere from that one screen. It's like it's frozen or something. So frustrated! Any advice?
How do i turn the timer off?  I tried tapping the button on the left and tapping my screen.  I was able to get back to other features, but the timer continued.  I tried holding the button in 2 sec, same result.   I tried pushing the pause arrow first, then the left button, to no avail.  After 18 min it decided to give me a Finish flag, which I pushed.  I had actually finished my activity, a brisk dog walk, several minutes ago.  It seems to think I am running and is timing my runs for me, which I don't want, but fails to notice when I am seated in my chair hunting for stop answers on the internet.
Thank you for that classification, I had no idea there was even a "touch" button on the left side! 😅🤦 & Now I'm back to my home screen and can stop the alarms! 🤣
to turn off, keep pressing left button till you get to ‘Home’ screen.
to change countdown period
Press pause icon II
SWIPE UP
Press circular go back icon
Touch the displayed countdown time
swipe up or down to get to your desired countdown period.
good luck.
Thank you! Had not been able to reset my stopwatch back to zero and your directions worked. So easy when you know how.
