03-29-2016
10:03
20:15
03-29-2016
10:03
20:15
My Fitbit Charge HR seems to be over-estimating my step count and/or mis-assigning workouts based on motion. Specifically, yesterday I spent 6 hours driving, I got in the car in the morning with something like 1300 steps. By the time I got home it had counted an additional 8k + steps and logged some of the time driving as bike rides. I got out of the car maybe twice on my trip, and it could not have been more than 100 steps total.
I understand that the hand placement and vibration of driving might "confuse" the device, should I be taking it off when I drive to ensure I get an accurate count? I prefer keeping it on because it tracks my HR and heps me control my stress level while driving (I'm near WDC - it's brutal here). This seems to be a more recent issue, I did not have this problem (or not this noticeably) until yesterday.
04-02-2017 20:07
04-02-2017 20:07
Best Answer04-02-2017 20:36
04-02-2017 20:36
No problem. I was hoping someone would have some helpful information as to why my Charge 2 is not properly recording steps.
Best Answer04-02-2017 21:55
04-02-2017 21:55
Sorry I am so.dumb.
So to clarify I put
Wrist Placement as Left
And Handedness as Left
When my dominant hand is right and wrist placement is left currently....Sorry I am dull....not to mention at work dog tired. Lol.
Best Answer04-02-2017 21:56
04-02-2017 21:56
I just need to know what to change. Sorry.
Best Answer04-20-2017 07:56
04-20-2017 07:56
hello do u return your fitbit?it happens to me i just sit for 1hour suddenly it increases 700steps and 500cals
even my "active" doesnt change since i use this alta still 0
i think i have to return it, fitbit so inacurate i even get replacement bfore this
Best Answer04-20-2017 08:14
04-20-2017 08:14
04-20-2017 08:46
04-20-2017 08:46
i think i will return it than get the replacement..thankyou for let me know, actually i bought this bcause the design its better than vivofit but its ridiculos and pricey
Best Answer05-19-2017 22:50
05-19-2017 22:50
My new fitbit blaze does the same thing. I will walk 100 steps and it will say I i somewhere between 60-70 while my husband's new fit bit blaze says 100 as he is walking beside me. I take more steps than him as I am 10" shorter than him. Thinking it was my fitbit we switched. I wore his & he wore mine. My fitbit calculated correctly for him & his was incorrect for me. We checked the stride on both. They are both set to calculate stride automatically. His shows a longer walking & running stride, in which it should. We walk quite briskly and if anything my arms swing more than his. We both wear it on our non dominant arm & they are both set for that. How do we fix my fitbit so it actually works properly & actually counts steps because obviously that is not what it is counting.
Thank you!
Best Answer07-03-2017 21:50
07-03-2017 21:50
Hello
I also work in customer service and was wondering if you figured out how to remedy the "over counting" problem since we use our hands so much during work .... i wear mine on my dominate hand because i am also not fond of wearing watches on my left hand.... i have tried changing my stride length switching setting from dominate to non dominate reset my fit bit etc etc ...
Help 😢
10-05-2017 17:18
10-05-2017 17:18
I have done everything you stated here, and I get such huge inaccuracy in my steps , just for a simple example I could walk a simple 5,000 steps and it records 21,000. no kidding, been doing this for 2 days now... I restarted it, did firmware update, contacted customer service and they said to just wait and see if it resets at midnight, but like I said to them that doesn't solve my issue of the over steps inaccuracy.. I could stand a few hundred but holy cow a few thousand is ridiculous ....any suggestions ?
Best Answer09-03-2019 19:35
09-03-2019 19:35
Why this cant be fixed in a firmware update. Ii guess the fitbit versa is having inbuilt gps, judging from the speed of travelling it should be able to figure out that the person is on a commute and need to avoid counting inaccurate steps.
I had used cheap huwawei band 2 and the step count is super accurate. And this expensive fitbit is giving me wrong stepcounts.
Best Answer09-14-2019 12:35
09-14-2019 12:35
Fitbits are more toys than anything close to accurate devices.
09-27-2019 19:17
09-27-2019 19:17
This is correction steps, but do we have anything to prevent logging it wrong g?
Best Answer01-05-2020 04:43
01-05-2020 04:43
My fit bit is over counting my steps and counting steps when i move my arm can you please tell me how i can correct it so it counts accurately! And in your previous posts it says about stride!l, i can’t find that! I am not very technical please help me! Thank you
Best Answer01-05-2020 04:58
01-05-2020 04:58
