Integration with mypt hub
Hi
Does anyone know how to integrate their fitbit with mypt hub as a client? I've selected integration on the mypt hub app but not sure where to go from there?
Thanks
5 REPLIES 5
@Loulouster It's great to see you in the Community!
Let me help you with your MYPT hub integration. The third party app should have a Fitbit option where you can enter your login credentials to connect both platforms. If you can' find this option then react out to MYPT support for instructions.
Let me know how it goes.
Alvaro | Community Moderator
Got It all sorted thanks!
Was mypt hub side that was the issue.
@Loulouster thank you so much for the update.
Could you let us know more about the issue and how you resolved it? This may help other mypt hub users in the forums.
I look forward to your reply.
My trainer had my email in mypt hub without one character.
Nothing complex
Oh that's really simple but it has happened to all of us. Thank you for the clarification. Hopefully you are already back on track and getting all those steps to keep a healthy lifestyle @Loulouster.
Happy stepping and stay safe.
