02-10-2019
01:23
17:54
02-10-2019
01:23
17:54
My partner and I are currently doing the couch to 5k programm.
The problem is, the Charge 2 only allows the user to program one active and one rest period for interval training.
In some weeks of couch to 5k you need to run for x minutes, walk for y minutes, run for z minutes etc etc..
Sometimes you want to walk, jog, sprint etc.
Having provision for allowing just x minutes active and y minutes rest is simply not cutting it.
It ought to take the guys coding your app a few minutes to add the lines of code necessary to expand this functionality into something useful in all scenarios.
Couch to 5 k is huge, there must be 1000s of frustrated Fitbit owners stumped by this baffling limitation!
Hi @Yodonsen,
As you discovered, C25K program is kind of awkward with Fitbit's Interval app. Because the Charge 2 doesn't support 3rd party apps, we're less likely to see one for that model.
However, for the Ionic and Versa, it appears to be here already.
