10-10-2018
07:20
15:47
10-10-2018
07:20
15:47
When attempting to change the clock face from the app on my iPhone it searches for a few minutes then says failed to install. I have restarted my phone and the Fitbit.
10-10-2018 11:57
10-10-2018 11:57
Same thing was happening to me. I had to update the Fitbit app on my phone. After I did that, I was able to change my clock face.
10-10-2018 11:57
10-10-2018 11:57
10-12-2018 20:28
10-12-2018 20:28
I have the same problem. Am using an Android phone and the tracker has been updated to the latest version. The original clock display is also not getting installed now.
01-17-2019 12:21
01-17-2019 12:21
My app is up to date but the clock face still won’t install. The watch tells me to try a different clock face (which is what I want to do) but the only options on the app are ‘continue’ or ‘try later’, there is no option to cancel - I am very annoyed!
01-18-2019
05:49
07:57
01-18-2019
05:49
07:57
Welcome to the Community @adrenalinjunkie.
I appreciate all the efforts in trying to fix this clock face inconvenience and would like to know if you keep having this problem? Have you tried the tip provided by our friend @Michelle1350? Are you receiving any type of error at the moment of changing the clock face?
Hope to hear from you soon. ![]()
Best Answer01-18-2019 07:08
01-18-2019 07:08
Thank you for getting back to me.
Everything - my iOS, my App and my watch - is up to date.
I have uninstalled the app and then reinstalled it, same problem. I have reset the watch using a long reset, 15 seconds, but it made no difference.
The watch tells me "Clock error. Go to the Fitbit app and try another clock", the app tells me there has been an error installing and I can try again now or later. If I try to install a different clock face it tells me that I have to wait until the other one has installed - ie I'm just going round in circles!
I rang the support number this morning but so far they haven't been able to help either.
I've only had the watch 1 week and was doing well with it, now I am fed up!
01-20-2019
03:24
07:55
01-20-2019
03:24
07:55
I appreciate your participation in the Community @adrenalinjunkie.
Thanks for letting us know about the issue you are experiencing with your clock face installation.
We are aware of the problem and are working to resolve it as quickly as possible, sorry for any inconvenience it's caused and appreciate your patience and look forward to getting you back on track.
Please let me know if there's anything I may do to assist you in the meantime. ![]()
Best Answer01-21-2019 20:37
01-21-2019 20:37
I'm having the same problem with my brand new Charge 3
01-22-2019 03:52
01-22-2019 03:52
They emailed me this morning to say they are going to replace the 'pebble' ie the bit between the straps!
Best Answer01-22-2019 09:17
01-22-2019 09:17
Best Answer01-25-2019 04:14
01-25-2019 04:14
Was the installation of the new clock face issue finally resolved. I'm having the same problem and think I have tried all the solutions. Any suggestions?
Best Answer01-25-2019 04:45
01-25-2019 04:45
No, it wasn't resolved, they are going to change the watch for me.
Best Answer01-25-2019 05:15
01-25-2019 05:15
Best Answer02-04-2019 10:25
02-04-2019 10:25
I'm having the same problem with my Charge 3. A few days ago I switched clock faces, with no problems. I tried to switch back yesterday...and now it's completely stalled. I've uninstalled the app on my Android phone, reinstalled it, shut down, restarted, restarted my Charge 3...and I'm still being run around in circles.
Has anything worked for anyone out there in Android land?
Best Answer02-04-2019 10:28
02-04-2019 10:28
Hi adrenalinejunkie,
Could you share the contact phone number that you used to get the new pebble/talk to a real person? I'm having the exact same problem as you are.
Best Answer02-04-2019 10:41
02-04-2019 10:41
Best Answer02-16-2019 21:31
02-16-2019 21:31
Thanks for sharing. Just bought it tonight to replace my Alta HR and not happy. Will call. If not resolved, may have to fully become an iPeople. 😕
Best Answer09-06-2019 15:24
09-06-2019 15:24
have the latest update of the fitbit app, just bought charge 3 and unable to change the clockface..
ALso trouble with it Syncing as ongoing like my Charge 2 did
Best Answer09-06-2019 15:27
09-06-2019 15:27
yes, still having trouble..I have just placed the fitbit app on phone when I bought the charge 3..it is very annoying..
Also having issues with syncing the watch
Best Answer07-25-2020 20:42
07-25-2020 20:42
How do you update the app. I thought it was updated. I have tried for days to get a new clock face but just get the endless loop like it can’t sync. Help I hate this clock face
