02-09-2021
15:15
03:03
AlvaroFitbit
02-09-2021
15:15
03:03
AlvaroFitbit
The LED lights are no longer visible on my charge 2, have restarted it a few times & theres no change. No HR/BPM registered or detailed sleep stages. Also a few black lines across the screen.
@Teddy9 It's great to see that you've visited the Fitbit Community!
Let me help you with this. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it (the restart should help with both the heart rate sensor and the screen). Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Hope this helps.
10:06
10:12
02-25-2021
10:06
10:12
@Teddy9 thank you for trying my previous suggestions.
Since the issue persists I suggest you contact our Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
I'll be around.
