08-18-2020
12:06
19:41
08-18-2020
12:06
19:41
I bought two chargers but neither fit. What charger would I need to buy that fits the following? 3 gold dots in a row, followed by a single white dot, a screen like thing underneath, and a single white dot below that. I can’t figure how to add a picture. The Fitbit is at least 4 years old.
08-18-2020 12:07
08-18-2020 12:07
Best Answer08-18-2020 12:12
08-18-2020 12:12
Hi @Loulou40 which Fitbit do you have? If you had an account before, it would tell you which device you last used. The Charge HR original charger unit can be found here - click to go there. You'll find many third party chargers don't always work with Fitbit devices.
Best Answer08-18-2020 12:13
08-18-2020 12:13
Merged your posts. You don't need to post this in more than one place.
Best Answer08-18-2020 14:11
08-18-2020 14:11
Best Answer08-18-2020 14:39
08-18-2020 14:39
You say you have the Alta but you posted in the Charger HR forum. Did you buy the correct charger?
Wendy | CA | Moto G6 Android
02-03-2021 13:53
02-03-2021 13:53
I'm going to say it depends what kind of Fitbit you have
Best Answer02-03-2021 14:16
02-03-2021 14:16
@Galaxykitten111 I already replied to your post. This one is an older thread, from six months ago. By now the original poster should have found a charger unit.
