05-29-2020 11:33 - last edited on 09-16-2020 19:33 by
My Charge 3 has not synced in 24 hours. I have shut down the phone, uninstalled and reinstalled the app. I went to settings and tried to manually sync the device. Nothing happened. Please help
Hi, and welcome to the Community!
Having tried restarting your phone without any luck, I would try restarting your Charge 3 by putting it on charge and pressing the button for 8 seconds.
You might also try "forgetting" any link to the fitbit in your phone's bluetooth settings. There are a few more things to consider in Fitbit's troubleshooting guide at Help article: Why won't my Fitbit device sync?
Best AnswerI tried everything you suggested. Now my Charge 3 will not pair with my phone. It says incorrect pin or passkey. I am getting very frustrated because this situation has never happened before
Best Answer@GregA75 welcome to the forums. The Fitbit uses bluetooth, but you don't pair it where a pin or passkey is required. Read this article - click to view - on how to set up.
Best AnswerWhich phone do you have and is it on the list of compatible devices? click to see
ok, it does seem to be on the list.
**Your posts were merged to keep them in one thread to make it easier for replies.
Best AnswerI'm having this same issue. Worked great from Christmas 2019 to recently. Now it won't stay synced. To get it to sync I have to try and re-set-up the Charge3 (on my Pixel 3) several times for 1 sync. I've tried all the tips and tricks I've found here and on other threads with no luck. I'd be interested in learning if you find a successful method to correct our issue. Thanks!
