02-04-2016
13:46
20:15
02-04-2016
13:46
20:15
Trying to set up my fit bit and showing 135❤️ On the screen and not a 4 digit code to enable me to set it up. I've tried to turn it off by holding for 12 seconds. Still staying the same. Please help.
Moderator Edit: Subject Clarity
Welcome to the forums @Lucieh247
Did you remove the sticker on the face of your ChargeHR? It's something easy to miss when setting up.
Let us know.
Best Answer@Lucieh247 You're not the first one to post about this. At least you found the community and know where to come for support, as well as for meeting people.
Glad you got it going!
Best Answer@Lucieh247 Try a restart of your ChargeHR - click for directions
Let us know what happens.
Welcome @Lucieh247! I'm so glad to know that @Odyssey13 was a big help for you. If you're still having issues with your battery charging, you can check the following:
- The charging cable is plugged into a working USB port.
- The end plugged into the tracker fits securely.
- A battery image appears on the tracker's display.
I also want to take advantage of this opportunity and encourage you to take a look at our Discussions bard, there you'll find a lot of friends to share with.
I can't find the 4 diget # to set up fitbit Alta HR, only found time in plastic face cover
Best AnswerI am not getting the 4 digit code for setup. I have it plugged to charge. All I have had is a scrolling www.fitbit.com/setup
