11-27-2016
06:41
10:26
11-27-2016
06:41
10:26
Just got a fit bit. Put it on charge , it vibrates but I get no display ( not even a battery charging icon)
Thanks - tried this but no joy so will take it back to where it was bought from and ask for an exchange. Thanks for your help
Restart
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help I would take it back to where ever you bought it and exchnage it. If you bought it at Fitbit then Contact Support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
The only display is full charge display after restart.
Bluethooth not working so cannot sync with app.
How to resolve this issue ? thanks all for sharing their inputs
Best AnswerIf there is no display, how do you reset it? The directions say to plug in and push the button. What button?
I have this problem too. I thought I would be smart and remove it so I could set it up again but I forgot that I would need the number on the Charge 2 to sync it again. Is there any other way of syncing it? Is there any way of seeing the number other than on the watch??
