01-23-2017
08:23
10:13
01-23-2017
08:23
10:13
My Charge 2 stopped sending notifications / reminders and stopped vibrating over a week ago. I've followed all of the directions in HELP to try to fix the problem but nothing has worked. Not sure what else to do.
01-23-2017 08:30
01-23-2017 08:30
@andreaco, have you checked your Charge 2 tracker to make sure the notifications did not accidently get turned off? Press the side button for a couple seconds until the screen displays "Notifications" On or Off - use the switch to toggle between Off and On. If that accidently gets set to off, you will not receive any notifications.
01-23-2017 08:19
01-23-2017 08:19
My Charge 2 stopped sending notifications and stopped vibrating over a week ago. I've followed all of the directions in HELP to try to fix the problem but nothing has worked. Not sure what else to do.
Best Answer01-23-2017 08:30
01-23-2017 08:30
01-23-2017 12:28
01-23-2017 12:28
Thanks Larry!
Best Answer02-22-2017 07:02
02-22-2017 07:02
My notifications are on. I get text alerts (from my phone), but it doesn't vibrate to remind me of the 250 steps. It did when I first got it, but not now. Not sure how to fix.
Best Answer02-22-2017 07:28
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
02-22-2017 07:28
@SarahInMaine wrote:My notifications are on. I get text alerts (from my phone), but it doesn't vibrate to remind me of the 250 steps. It did when I first got it, but not now. Not sure how to fix.
Unfortunately this has been broken for months (since the last firmware update) and we are still waiting on a fix. Fitbit has been incredibly slow to resolve this issue. I wish it worked again as this was the main feature I requested and the reason that I "upgraded" from the Charge HR.
02-22-2017 10:12 - edited 02-22-2017 10:13
This isn't just an issue since last firmware. I have owned a charge2 HR since they first came out. I am on my third device now which just stopped vibrating after a couple of months just like my prior 2 devices. I have been through all the steps suggested on here and by technical support nothing worked. The first time they sent me a new device immediately and the process was smooth. The second time not so much, they made me send my defective device back first (which was ok by me) but took forever for them to check the device in and send me a new one, which they only sent the electronic portion, no wrist band or charger, after contacting them they sent me a wrist band and charger, unfortunately they sent the wrong wrist band. Finally after about 2 months i finally was able to wear it again. Sadly though this new one stopped vibrating altogether also. At this point I wish I could get my money back and go with another device, but do not think its possible. Was very happy with the device, but apparently the motor that provides the vibration must have a short life span.
Best Answer03-03-2017 19:37
03-03-2017 19:37
Fixed the problem. Thank you🤗
Best Answer03-04-2017 04:31
03-04-2017 06:58
03-04-2017 06:58
Did not work for me. Notifications are on. Fitbit vibrates when texts come in. Does not do the 250 step thing. Did the hard reset per website instructions. Did not help.
Best Answer03-04-2017 06:59
03-04-2017 06:59
Same here. Still not getting the 250 steps notifications. It is now March 4. Needs firmware fix.
Best Answer03-05-2017 08:17
03-05-2017 08:17
@SarahInMaine wrote:Same here. Still not getting the 250 steps notifications. It is now March 4. Needs firmware fix.
Fitbit still has not fixed the issue. The workaround (which has been working for me this past week) is to set heart rate to auto and make sure that notifications are on. I had my HR off to save battery and turn off the distracting bright green lights. I only want HR when working out (see my suggested feature in the link below).
Best Answer03-29-2017 05:27
03-29-2017 05:27
Same thing has happened to my Fitbit and the customer support team is ignoring our desperate emails! The notifications and alerts are on, on both my Fitbit and on my phone yet nothing.
03-29-2017
05:28
17:23
EdsonFitbit
03-29-2017
05:28
17:23
EdsonFitbit
Press and hold the button on the side of your fitbit! It will switch and
say "notifications on"
Life saver!
Best Answer03-29-2017 05:51
03-29-2017 05:51
After I posted (above) I finally called. The re-set using the button on the side wasn't fixing the issue for me. She had me remove my old Charge HR, which was also on the account, then do the re-set (and perhaps something else, don't remember precisely), but that fixed the problem and my 250 steps reminder is back. Luckily, I don't wear the old Charge so I don't need to have both on the account. Hope this helps.
Best Answer03-29-2017 05:53
03-29-2017 05:53
Best Answer04-04-2017 16:53
04-04-2017 16:53
That was so helpful and no where else could I find that fix. Thank you Larry from Ohio! Shannon from PA
04-04-2017 16:56
04-04-2017 16:56
Great to hear it helped you, @Shannongnas! Keep on Stepping!
Best Answer05-05-2017 08:58
05-05-2017 08:58
I feel as if I'm giving a stupid answer, but you do realize you don't get the reminder for the 250 steps if you have already done that many steps in the current hour.
05-05-2017
09:04
17:24
EdsonFitbit
05-05-2017
09:04
17:24
EdsonFitbit
Thank you yes, I knew that. This was for hours with under 250 steps. However, Fitbit solved it by removing my other (older) Fitbit from the app.
Cheers, Sarah
