03-26-2020
17:55
10:02
03-26-2020
17:55
10:02
I did a 35 minute walk today and the fitbit did not recognize it like it usually does even though it added the steps to my daily total and the active minutes. When i added it manually it reduced my number of steps significantly and said i only burned 2 calories a minute even though i went through all 3 heart rated during that time. So i deleted the manually entry
03-27-2020 21:28
03-27-2020 21:28
Are you relying on the Smart track? Sometimes its better to use the exercise mode to make sure you capture the exercise
You can have up to 7 exercise shortcuts. On your dashboard click on the gear and choose settings. Look for exercise shortcuts. Change to what you want.
When you go out select Walk and push the button in to record it. When done Stop it the same way
Wendy | CA | Moto G6 Android
Best Answer04-01-2020 23:24
04-01-2020 23:24
I didn't understand your reply
2 days this week it recorded my walks, days 3 & 4 it didn't (messed up my quest for 5 days this week)Thanks Neena43
