06-07-2020
08:47
17:22
06-07-2020
08:47
17:22
So far enjoying my fitbit3 but another issue has popped up. Been wearing it a week now and have never gotten an oxygen reading!
Read a few posts about this with no real fixes. Can anyone give a simple fix for this.
When I had the sleep score issue a straightforward answer( disable all sleep settings) worked!
06-07-2020 16:57
06-07-2020 16:57
I've had this issue, too.
Few things to look into: your band may be too loose at night while you are sleeping, the sensor (I believe it is the red one) could use a cleaning, and/or you are tossing and turning too much for the sensor to get an accurate reading.
I hope you start getting readings soon! It sounds like people are buying the Charge 3 for this capability and it would be nice if it realiably worked. 🙂
Good luck!
06-07-2020 18:50
06-07-2020 18:50
