05-28-2022
15:29
14:23
05-28-2022
15:29
14:23
Hi all
For some reason my phone isnt adding up my steps ect, I have a charge 4, was messing other day as it wasnt coming through to my watch messages n calls. I dont knw what Ive done, any help pls?
05-28-2022 19:38
05-28-2022 19:38
Hello @SparklingJo
It sounds like a syncing issue between your phone and your Charge 4. Have you looked to make sure your Charge 4 is showing as connected on your mobile devices Bluetooth? It it is indeed connected try turning your Bluetooth off then on again. Now try to sync to see if that fixed the problem. If the problem persist then try changing your clock face. If that still doesn’t work maybe it would help to restart your Charge 4. You will not lose any of your data doing a restart. Look here to see how it’s properly done: https://help.fitbit.com/articles/en_US/Help_article/1186.htm
😉 Please let me know if this helped fix the syncing issue
Best Answer05-29-2022 09:35
05-29-2022 09:35
Hello again @SparklingJo
I’m just checking in with you to see if the troubleshooting tips I provided you help your syncing issues. 😉 Keep me posted on your progress
