I downloaded my Charge 3 data in an attempt to understand the EOV graphs visible within the application. For example, on 1/11/2021 12:12:22 AM I had a reading of -69 within the "Infrared to Red Signal Ratio" column. How does relate to the visual graph? What does this number mean? Do higher numbers reflect 'high' oxygen variation, where a lower number would indicate low variation?
I have the same question for my FitBit Versa 2.
Below a slight example of my estimated oxygen variation, "Infrared to Red Signal Ratio".
Can you please explain what I can read here? Also in relation to the visual graph?
04/03/21 04:43:08,-4
04/03/21 04:44:08,-83
04/03/21 04:45:08,-57
04/03/21 04:46:08,-69
04/03/21 04:47:08,-7
04/03/21 04:48:08,-64
49:09,0
04/03/21 04:50:09,-64
04/03/21 04:51:09,-11
52:09,0
04/03/21 04:53:09,-46
04/03/21 04:54:09,-43
04/03/21 04:55:09,-14
