08-30-2019
12:44
17:01
08-30-2019
12:44
17:01
08-30-2019 14:05
08-30-2019 14:05
Change Time
On the computer: Go to the Dashboard and click on the gear and choose settings from the drop down. Scroll down to time zone Change it to a different one. Sync it. Go back in and change it to the correct one and sync again
Phone: Click on account upper top right looks like an envelope. Scroll down to advanced settings and do the same as above
Device will need to sync before it changes
Also check your computer and phone to make sure the time is correct on it as well.
For syncing there is no link. Open up your app and it should start syncing. If it doesn't click on the icon of the device and you should see a Sync now
Wendy | CA | Moto G6 Android
