09-22-2022
18:13
08:01
AndreaFitbit
09-22-2022
18:13
08:01
AndreaFitbit
I've had my charge 3 for just under 2 years. Feb 2021 I think it was. Brought brand new. About 9 months ago the screen went really dim (still visible by tilting my wrist) and never brightened up even after restarts and brightness adjustment. It still worked so I didn't bother doing anything else. Yesterday half the screen was completely gone and now today - the whole screen is blank. It's still registering steps and counters and syncing with the APP. Still vibrating. Just a complete black screen.
any help would be appreciated.
09-24-2022
08:04
10:51
09-24-2022
08:04
10:51
Welcome to the Fitbit Community, @EmzR9374782. I´m sorry to hear your Charge 3 screen is blank. Thank you for letting us know that you have tried restarts and brightness adjustment to correct this.
Please try the long restart:
10-01-2022 15:12
10-01-2022 15:12
Hi,
I followed the instructions as above. The brightness come back to the screen, however, about 25% - 30% of the screen is still missing. 2 strips down each side of the watch face missing with only a panel down the middle showing.
If I press the button on the side 50% of the time nothing happens, the screen just stays blank. Also I'm getting no more notifications on messages and calls etc even though it was linked to my phone and the feature where the screen would light up if I lift my wrist to "check the time" has also gone.
10-02-2022 08:12
10-02-2022 08:12
I did follow what the instruction said but still blank with just vibrations.
10-04-2022 02:19
10-04-2022 02:19
There seems to be a common problem where the display on Charge 3 stops working. Some people (including me) have found that restarting fixes this: Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
Regards,
Will
10-04-2022
07:34
10:11
10-04-2022
07:34
10:11
Thanks for getting back to us and for following advised troubleshooting steps @EmzR9374782. Welcome, @DodoNeo. Thank you for letting us know that after following the instruction your Charge 3 is still blank with just vibrations.
Could you please confirm that you have tried changing your trackers clock face?
Thank you for your advise @willjoe.
10-04-2022 07:45
10-04-2022 07:45
Yes, but still blank.
10-05-2022
07:04
10:05
10-05-2022
07:04
10:05
Thanks for getting back to us and for following troubleshooting steps @DodoNeo.
I went ahead and created a case on your behalf and a customer support representative will contact you soon.
