09-20-2017
04:11
09:26
09-20-2017
04:11
09:26
Time on Fitbit charge 2 is set in letters e.g. Twelve oh nine, I want it to be in numerals preferably 24 hour clock. How to I change to 24 hour clock
09-20-2017
05:31
06:22
AlvaroFitbit
09-20-2017
05:31
06:22
AlvaroFitbit
You can change between 12 and 24 hour clocks in your profile settings at https://www.fitbit.com/settings/profile
And you can choose a different clock style with the info you want in your device settings at https://www.fitbit.com/settings/device
Once you have made the changes and saved them, the next time you sync your fitbit will be updated.
09-20-2017
05:31
06:22
AlvaroFitbit
09-20-2017
05:31
06:22
AlvaroFitbit
09-20-2017
09:16
06:22
AlvaroFitbit
09-20-2017
09:16
06:22
AlvaroFitbit
Thank you. I have followed instructions and am now happy with clock face and 24 hour clock. Thank you for your help. Will save these instructions for the future
Sent from my iPad
Best Answer03-14-2019 14:24
03-14-2019 14:24
Does not work for me; error message for last name
Best Answer03-15-2019 00:49
03-15-2019 00:49
Is it complaining about your last name being blank? That happened to me a year or so back. The problem is that the field was initially left blank when we create an account but the rules changed at some point such that it has to have a name. If you try to amend any part of your profile it wants you to "correct" this.
If you don't want to give your name then put in anything. Then you can change the clock.
Best Answer03-15-2019 09:59
03-15-2019 09:59
Best Answer03-15-2019 10:05
03-15-2019 10:05
That's something I have not come across before so I'm not sure what to suggest.
If you don't get an answer from someone in this thread then you could contact customer support to see if they can help: contact.fitbit.com
03-22-2019 01:42
03-22-2019 01:42
Your suggestion works, but "only" on my laptop and not on tablet. Thanks!!!
