Setting Charge 3 main goal
ANSWERED
This relates to the Charge 3, but there wasn't an option for it...so I apologize in advance. When I first got my watch, I set my goal distance at 2.5 miles. I just did a complete system update and re-sync, and I thought I changed the distance goal to 2 miles because my dog is getting older. But wearing my watch this morning, we did 2.85 miles and the vibration never went off at all. What am I doing wrong?
1 BEST ANSWER
Accepted Solutions
Thanks for getting back to us and for sharing the steps you've followed @jcm48
The instructions I sent you on my last post were to set the goal.
To change the miles goal:
  1. Go to Today and Tap when you get the distance.
  2. Select the gear and you'll get to the goals.
  3. Tap distance and change your goal.
  4. Select OK.
  5. Your miles goal will be changed.
I hope this information helps.
4 REPLIES 4
Hi @jcm48  your post was moved to the Other Charge Trackers forum area, which best reflects your need. The Moving forum is for people discussing their walks, runs or advice on how to improve one's fitness goals. Anyhow, for your issue, did you sync after resetting your goal?
Here are directions - click to read
Stepping in the U.S.A. since September 2013. Android 14
Thanks  for getting back to us @jcm48. Thank you for sharing your goal inquiry.
Choose Distance as your main  goal and when you reach your goal, your Fitbit device flashes and vibrates.
To change your main goal on your Fitbit device?
  1. Tap the Today tab
    , and tap your profile picture.
  2. Tap your device image.
  3. Tap Main Goal, and choose your goal.
Thank you for your advise @Odyssey13.
Andrea, there's no place for me to enter my miles goal: when I click Main Goal, I get a box with a drop-down list; when I choose Distance, there's nothing that lets me put in the number of miles. I'm obviously missing something............😲
  4. Select OK.
