06-01-2017
04:56
09:49
06-01-2017
04:56
09:49
I forget how to set the time and I am changing time zones. Can someone help?
06-01-2017 05:15 - edited 06-01-2017 05:18
You can go here (scroll down to time zone and use the drop down to alter the timezone) to manually set your timezone for the next time you sync your tracker.
Note: Your mobile should automatically adjust as you travel, changing time zones as it first communicates with local towers, when you sync your mobile and tracker the accurate time will transfer.
A bit different than the days when you got on the plane and manually set your timepiece for your destination - now you get there and everything auto adjusts.
Without your mobile on the trip you won't be syncing so be patient until you get back, your individual fitness stats will hold for a week, summary stats for a month. (don't forget a USB charger and your charging cable if more than a few days away)
Hope this helps. Have a smooth trip @Logger, nice to meet you!
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
WmChapman | TX
06-01-2017 05:46
06-01-2017 05:46
Thank you. That worked!
07-04-2017 07:59
07-04-2017 07:59
I charge the battery but it's not showing the correct time
Best Answer07-05-2017 23:33
07-05-2017 23:33
@Sweet47p was the battery dead and your tracker shut off? This would explain the time being off. Have you synced tye tracker since charging the tracker? If you havent, then your time wont be set.
Best Answer07-06-2017 11:15
07-06-2017 11:15
Best Answer08-27-2017 17:56
08-27-2017 17:56
Time and Date still wrong.
08-28-2017 04:20
08-28-2017 04:20
Hello @mclean-5257, ive moved your post to a relevant thread. Please see the solution above
Best Answer09-11-2017 19:15
09-11-2017 19:15
I have it set correctly but my Alta doesn't change with the time zone. How do I fix that? Thanks!
Best Answer09-11-2017 19:52
09-11-2017 19:52
Best Answer02-10-2018 02:26
02-10-2018 02:26
My watch is still of one hour off
Best Answer02-10-2018 02:32
02-10-2018 02:32
Reset time
Best Answer02-10-2018 13:30
02-10-2018 13:30
Have you read the solution above @Oneleg, that is what I would right.
You can also look at the Fitbit help doc.
Best Answer12-28-2018 08:58
12-28-2018 08:58
Sure would be nice to be able to see the correct time without an internet connection. When traveling, I can start fitbit sync but without being online to internet it will NOT update time or synch. I know my laptop, iPad and phone all connect properly but without an internet connect they do nothing. No synch, no time change.
Best Answer07-19-2019 05:59
07-19-2019 05:59
My time has changed to the time zone where I travelled, but will not change back now since I am home. Any help would be great.
Best Answer07-19-2019 15:06
07-19-2019 15:06
Do you get any errors reported when changing the timezone @dniner?
Are you doing this through the Fitbit app on some type of phone or computer, or using the web portal?
Have you tried both?
On the phone have you tried both manual and auto modes?
