09-01-2017
03:16
09:26
09-01-2017
03:16
09:26
Hi
This may be a really easy question but it's puzzling me. When I'm running I want to see my current pace ,the distance I've run and how long I've been running. Is there a way to individualise displays? It's not easy to run and look at the display and scroll through to see the stats you want so I'd like to be able to see the ones that are important to me on the first screen that shows.
Thanks
Welcome to the Fitbit Community @CDan81, hope you're doing great today!
Not at this time my friend. To see your stats, during your workout, you need to tap your tracker to scroll through real-time stats or check the time of day.
I'd recommend checking out our Feature Suggestion Board if you haven't already. This is a space where Community users can post features, ideas, and suggestions that they'd like to see in future Fitbit products, accessories, and software and top-voted suggestions get relayed to our product team for review.
I'd also recommend up-voting and commenting on Display pace, distance and time in the same screen while running feature suggestion since it is very similar of what you're looking and asking for.
Enjoy the rest of your day!
Best AnswerSolution,
1.Use fitbit apps on your smart phone. At main page, tap "weekly exercise', you will go to next page.
2. At right top comer, tap the icon (looks like a clock), there will be two tabs are showing up. Tap "track"
3. there will be three line below track, select Run, then click the "Cues", it will give you chose how you are going to hear about you data, such as pace, distance etc. You also can set up the frequency, such as every mile or two miles, Or the time such as 2 or 3 minutes etc.
4. Select the music if you want listen during the run.
5. Wear your earphone and press start to start your run. then you will be enjoy the announcement through your earphone for your pace, distance etc.
You will be all set!
