03-02-2019
09:09
11:22
03-02-2019
09:09
11:22
my sleep data used to track sleep stages (rem light awake and deep sleep ) and had been ok up until I charged it today. When I looked after charging it had changed my data for last Tuesday to say I had almost 16 hrs sleep (I didn’t) and it’s tracked sleep differently with sleep quality and a different chart.
03-05-2019 03:21
03-05-2019 03:21
Hey there @Dawn12345, thanks for stopping by! If your Charge 3 is no longer tracking your sleep stages, I'd recommend restarting your Fitbit.
Additionally, please make sure you follow the tips and recommendations to get sleep stages. The information can be found at: What should I know about sleep stages?
In regards to the 16 hrs slept, are you looking at your Fitbit app? If you can you please share with me a screenshot of it? Also, I was wondering if by any chance you did not manually change the sleep history?
In the meantime, I'd recommend doing the following:
Looking forward to your reply!
Best Answer01-07-2020 21:46
01-07-2020 21:46
The same has happened with my app... the sleep graphic has changed. Just awake, restless and sleep bars. No more REM, light sleep, deep sleep etc..
Best Answer03-29-2020 05:58
03-29-2020 05:58
I am also being asked to upgrade to premium to get sleep data. Wow, I sure paid a lot of money for a step tracker. Will not be buying another Fitbit. Very disappointed.
