04-17-2017
23:34
09:49
04-17-2017
23:34
09:49
Can someone please tell me what the stat FT is, following exercise? Also, when I select spinning as an exercise activity on the app, it automatically reverts to the pre-selected list before it can be synced, with the result I can't track spinning on my device. Hope that makes sense. Thanks.
04-18-2017 01:32 - edited 11-06-2017 19:29
Not really, where is the FT being seen?
Not sure but are you saying that when you try to add spinning to your tracker, your unable to do this?
Have you tried through the web interface yet? Http://help.fitbit.com/q=multisport
11-06-2017 18:49
11-06-2017 18:49
Ft shows when u complete interval exercise.
11-06-2017 19:33
11-06-2017 19:33
Reviewing the event on the web should give more of an explanstion.. Have you read your user manual yet? Or maybe check the help doc.
11-09-2017 06:22
11-09-2017 06:22
Have u received an appropriate response to your query on the meaning of FT?
11-07-2019 15:33
11-07-2019 15:33
No. What does FT stand for and what do the results mean? I mostly walk. The more intense my activity, the more numbers I get. Is it a fitness score?
11-07-2019 15:40
11-07-2019 15:40
what does FT mean? That's the only symbol that doesn't make sense to me.
11-08-2019 08:50 - edited 11-08-2019 08:56
@SA_Walk on what screen are you seeing the FT? Is this on the tracker, (note we are on the hardware board), or is this found in the fitbit app?
Maybe a photo or screenshot?
I merged your cross posting.
11-08-2019 09:27
11-08-2019 09:27
11-08-2019 18:03
11-08-2019 18:03
Hi @SA_Walk, welcome! It's great to have a new member around. @Rich_Laue, I appreciate your big help!
@SA_Walk, thanks for joining this thread. I've tried a walk activity on my own, however I wasn't able to get a stat labeled as "FT". As @Rich_Laue mentioned, is it possible for you to take a picture of what is displayed on your Charge 2 and share it with me? For instructions to attach a picture in your reply, please see this post.
I'll look forward to your reply.
11-08-2019 18:20
11-08-2019 18:20
11-10-2019 08:49
11-10-2019 08:49
I'm not seeing any FT on any screen.
11-10-2019 12:08
11-10-2019 12:08
11-10-2019 14:26
11-10-2019 14:26
Hi @SA_Walk and @Rich_Laue, I'm glad to see you here.
@SA_Walk, thanks for getting back and confirming that this start is displayed on the Charge 2 itself. Whenever you have time, attach the picture of your tracker showing the "FT" stat, this way I can continue helping you with this. You can find instructions to attach a picture in your reply here.
11-10-2019 17:22
11-10-2019 17:22
11-11-2019 16:09 - edited 11-11-2019 16:11
Hi LizzyFitbit and @Rich_Laue Trying to get you pictures from my Charge 2 shortcut stats. The last screen show FT
11-11-2019 16:29
11-11-2019 16:29
Hi @SA_Walk. Hope you're doing well.
Thanks for the pictures provided, they were very helpful. What you're seeing is the elevation tracked during your activity. Depending on the units set in the Fitbit app, this will be displayed as FT (feet) or m (meters). That's why I wasn't able to see the same details, as I chose meters for units. If there's anything else I can do for you, please keep me posted!
See you around. 😉
11-11-2019 17:11
11-11-2019 17:11
11-12-2019 10:37
11-12-2019 10:37
That's fantastic! You're welcome and I'm glad that you've found the answer for your question! In case you have some spare time, I’d like to invite you to visit our Discussion Board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Hope to see you more often! 😊
