01-31-2018
12:54
18:54
01-31-2018
12:54
18:54
I just bought a Charge 2 and have been using it for a week now. I also have an Apple Watch 3. I use them together, one on my left wrist, the other on the right. After testing for a week, i noticed that fitbit counts significantly more steps than Apple Watch. And I think AW is accurate. I have been using AW for quite a while, and i have tested its accuracy with other activity trackers. I will test Charge 2 for couple more weeks and i iwll return it if the inaccuracy continues.
01-31-2018 15:29
01-31-2018 15:29
The AW might indeed be more accurate but I am suspicious of just saying you think it is right without doing a simple test to check.
The way to see what is accurate is to go outside, or at least somewhere you can walk continuously, and count the steps as you walk, swinging arms naturally, not looking at tracker as you walk, the more steps the better, preferable at least a couple of hundred, and then see how your count compared to each tracker's count.
01-31-2018 15:38 - edited 01-31-2018 15:40
@xs_kurtosis which tracker is on the dominant arm? Have you switched the trackers between arms?
Both look at arm movements, not feet movements.
02-01-2018 09:59
02-01-2018 09:59
yes, I have done that many times. Thanks
Best Answer02-02-2018 12:29
02-02-2018 12:29
Got mine a few days ago and very disappointed with the accuracy. If out for a walk it counts fine, but round the house its nuts. This morning I sat up in bed and it added 297 steps. If it can't do the basic step counting its of little use - though I do love the app and the sleep info.
Best Answer02-02-2018 13:27
02-02-2018 13:27
Found the same problem. Changing bed linen apparently accumulated 500 steps....!???
wrote:Got mine a few days ago and very disappointed with the accuracy. If out for a walk it counts fine, but round the house its nuts. This morning I sat up in bed and it added 297 steps. If it can't do the basic step counting its of little use - though I do love the app and the sleep info.
02-02-2018 15:11
02-02-2018 15:11
Yes, it keeps adding huge amounts if steps. Wonder how accurate other fitness trackers are. Seems like a basic thing to get right before all the other stuff!
Best Answer02-02-2018 16:24
02-02-2018 16:24
Swithching the wrists definitely makes a difference. When i wear it on my non-dominat arm it gets closer to AW in step count, but still counts more steps.
Best Answer02-02-2018 16:33
02-02-2018 16:33
Neither unit is actually counting your steps, both are looking at arm movements to determine the movement of the feet. Each device used their own logic and I would be surprised if they matched.
02-02-2018 23:10
02-02-2018 23:10
Yes. Interesting though that I've been walking outside with my hands in my pockets (cold here at the moment)...or watching the Fitbit screen to check steps so arms not swinging by any means, and it is counting accurately on these walks.
Best Answer08-08-2018 11:02
08-08-2018 11:02
I did 2 trials today by (1) wearing the wristband on my left arm and set as non-dominant (2)hold my iphone in my left hand.
1st trial result (roughly 20min walk): 1487 steps (fitbit) vs 1632 steps (apple health app)
2nd trial result (roughly 10min walk): 691 steps (fitbit) vs 504 steps (apple health app)
so, the fitbit/apple ratio is roughly 100:75.
Best Answer08-14-2018 00:57
08-14-2018 00:57
May I ask @BiuBao how many steps did you physically counted?
We need to compare to a known count .
08-14-2018 03:56
08-14-2018 03:56
Best Answer08-14-2018 05:34
08-14-2018 05:34
I find when I'm driving it adds on an extra 1000 steps!check before start driving and after
08-14-2018 06:47
08-14-2018 06:47
If your numbers are posted here correctly:
Fit 1487/1632 app
Fit 691/504 app
Then the ratio you figured can't be right because one ratio has fitbit being higher and the other apple being higher.
Best Answer08-14-2018 09:06
08-14-2018 09:06
My fault, just checked screenshots. 1st trial should be the reverse: Fitbit 1632/1487 Apple app
Best Answer02-19-2019 21:17
02-19-2019 21:17
I am having the same issue. I got an Apple Watch for for Christmas. I’ve been using my Fitbit for years. I’m wearing both of them now, however, for a few weeks. The numbers vary, sometimes the Apple Watch reports more steps, more often the Fitbit reports more steps. I have not gotten scientific about it, and that is really the only way to know if the Fitbit is over counting steps. But generally the Fitbit is at least 1000 steps higher at the end of the day, compared to the Apple Watch.
02-20-2019 15:45
02-20-2019 15:45
Have you kept a daily log off the steps, then compared step totals over a week and month.
02-20-2019 16:34
02-20-2019 16:34
Best Answer02-20-2019 23:40
02-20-2019 23:40
While on a walk, which unit is accurate, or do their steps come close.
