Thanks for your reply @GWRGirl! I got you! Let me explain to you that this behavior is totally normal. After you press and hold the button to start the stopwatch, after 9 seconds, the display turns off, but you can turning it on by tapping or by pressing the button. So you don'r have to worry, because that is how the Charge 2 works. 😉
If you have further questions, let me know!
Best AnswerYou cannot prevent screen from going dark, but can also turn it on via wrist turn, I assume requiring you have "quick view" turned on, i.e. similar to turning wrist to view screen during normal usage.
Best AnswerAgreed!
I keep a clock-face with an analog sweep on my phone, and couple that with a metronome app timed at 60 bpm. Even then, I hate to interrupt a hold to see where i'm at, and sometimes I lose count of the beats on longer holds, or if there is a distraction at the gym.
I'm not sure the folks at Fitbit are actually using the stopwatch, themselves. If they were, I would think they would understand the problem with having to tap (needs two hands, rarely works the first tap) and with having to wiggle (hold may involve holding position (duh) ).
Plus they would notice the terrible pulse meter. Rarely during my workouts is it within 50 bpm, even placing the unit carefully as per instructions.
