09-07-2016
16:13
20:15
09-07-2016
16:13
20:15
09-09-2016 11:49
09-09-2016 11:49
@SteveJM welcome to the forums! That's a great question and I'll be happy to answer that! If you press and hold your Charge HR's button until it vibrates you will have a little stopwatch icon and voilá! You're all set. To exit the stopwatch mode just follow the same process.
Hope this helps, keep me posted!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
09-09-2016 11:49
09-09-2016 11:49
03-20-2019 15:03
03-20-2019 15:03
My problem is that I can't turn off my stop watch...it has been vibrating off and on for 4 hours now. I cannot get it to stop and I can't use my regular screen.
