09-07-2019
12:39
10:43
09-07-2019
12:39
10:43
Anyone else having this problem? My Fitbit was syncing just fine a couple of weeks ago. My phone did have an update which I didn’t update right away but it has suddenly stopped syncing up. So I updated my phone thinking that was it but no. Checked that my app was up to date which it was and have contacted customer support only to be ignored and I’m getting super frustrated. It literally worked two weeks ago. I’m now reaching out on Facebook to try to get answers but this is just eye roll worthy. Help!
11-13-2019 19:22
11-13-2019 19:22
Put the device on the charger, squeeze both sides to reboot. It fixes my issues, but I need to it anytime my watch gets wet.
11-13-2019 19:33
11-13-2019 19:33
10-29-2020 02:35
10-29-2020 02:35
Due to the update. Turns me off getting another fitbit when I can't track anything or receive any notification... A very expensive way to only get the time on display
10-29-2020 02:38
10-29-2020 02:38
It's mot a phone issue but a problem with the app program. All worked well previously but subsequent updates resulted in communication issues between phone and device... Bad show
10-29-2020 03:31
10-29-2020 03:31
10-29-2020 12:08
10-29-2020 12:08
What device is your app on?
Depending on what is updated, I find permissions get reset.
10-29-2020 12:19
10-29-2020 12:19
10-29-2020 13:54
10-29-2020 13:54
As for syncing issues with my SG8 I go into Phone Settings / Apps / Fitbit / Force Stop
Then go into Storage / Clear Cache.
