09-07-2019
12:39
10:43
09-07-2019
12:39
10:43
Anyone else having this problem? My Fitbit was syncing just fine a couple of weeks ago. My phone did have an update which I didn’t update right away but it has suddenly stopped syncing up. So I updated my phone thinking that was it but no. Checked that my app was up to date which it was and have contacted customer support only to be ignored and I’m getting super frustrated. It literally worked two weeks ago. I’m now reaching out on Facebook to try to get answers but this is just eye roll worthy. Help!
09-08-2019 08:35
09-08-2019 08:35
09-08-2019 08:51
09-08-2019 08:51
09-08-2019 08:52
09-08-2019 08:52
09-08-2019 08:54
09-08-2019 08:54
09-08-2019 08:55
09-08-2019 08:55
09-08-2019 08:56
09-08-2019 08:56
09-08-2019 08:59
09-08-2019 08:59
09-08-2019 09:01
09-08-2019 09:01
09-08-2019 09:02
09-08-2019 09:02
09-08-2019 09:03
09-08-2019 09:03
09-08-2019 09:49
09-08-2019 09:49
People are mentioning they are having issues but unless we know what type of phone, the best we can do is send you to the help docs.
@caj4 removing a tracker from the Fitbit app and therefore the users account is the worst thing a user can do. It simply adds more problems to a tracker that isn't syncing.
If the tracker has not been removed, we can concentrate on the sync issue. The app knows what tracker it is looking for. Once removed, we still need to fix the sync issue, then we can tell the app what tracker we want on our account. I'm not sure if Fitbit is able to attach the tracker back to the account, but that would be the best course.
You probably been here but..
09-08-2019 10:11
09-08-2019 10:11
Hello Rich; thanks for the message. I'm running a Motorola G5s, with the OS 8.1 Fitbit version 3.5. sadly I unpaired the charge 3 (which I bought from Currys PCWorld about 6 weeks ago. The charge 3 was fully charge this morning, but upon disconnecting it from the charger the display failed to work, and when I pressed the button the device started vibrating and wouldn't stop. I think it ran out of battery about 30 mins later.
I have recovered my charge 2; and paired that once more to use but I'm hoping you will have a suggestion soon.
Thanks
09-08-2019 10:34
09-08-2019 10:34
Hi @Pqr81 as for your Charge 3, your describing an internal problem and tje best course of action would be to contact Fitbit.
09-08-2019 14:12
09-08-2019 14:12
09-08-2019 14:57
09-08-2019 14:57
09-08-2019 19:43
09-08-2019 19:43
09-09-2019 06:04
09-09-2019 06:04
I tried all of the proposed solutions, yet again, to getting my new Fitbit 3, Bluetooth communication, to re-establish with my mobile without any success. However, the issue has now been resolved. I returned the Fitbit to the store today and received a full refund.
09-09-2019 06:18
09-09-2019 06:18
My Charge 3 also stopped working this weekend. I ended up fixing it.
Symptoms:
Solution:
What I found odd about the whole issue, that I had to use the Fitbit app to connect my Charge 3 to the phone, instead of using my phone's Bluetooth menu (where it would always fail.)
Hopefully these steps help some of you. Good luck.
09-09-2019 06:31
09-09-2019 06:31
@Carnby that is not odd, your tracker is a Bluetooth Low Energy device and why the Setup instructions mention that setup must be done through the app
I posted links to the setup procedure in my post above.
. There is nothing mentioned about using the Bluetooth of the phone.
09-09-2019 07:00
09-09-2019 07:00
I have had the same syncing issue for weeks now. I run on Android (Moto Z3 Force), and I have to restart my phone a couple of times a day to get it to sync.
