10-08-2018
21:48
15:47
10-08-2018
21:48
15:47
I bought the Charge 3 yesterday on launch day primarily because of the swim tracking feature. I like to swim but I don't like having to keep count of my laps while swimming, so I thought the Charge 3 would be good.
After buying the Charge 3 yesterday, I took it to the gym to try it out. I set the pool length setting to 25 yards, started a swim exercise session with a goal of 20 minutes, and started swimming. It vibrated to alert me after 20 minutes, at which point I stopped. I synced the Charge 3 with my phone. The session was logged correctly at just over 20 minutes, but it only showed me completing 5 lengths for 125 yards. I'm not the fastest swimmer but I'm sure I actually did around 30 lengths.
I contacted customer support yesterday and their only suggestion was to have me restart the Charge 3 and try again. So I restarted it and took it swimming again today. I did the same thing, manual swim session with 20 minute goal. This time it logged 3 lengths, for 75 yards.
I read the Help article here:
https://help.fitbit.com/articles/en_US/Help_article/2087/?q=swim&l=en_US&fs=Search&pn=1
and I am not doing any of the things listed that might cause incorrect swim data. I swim freestyle and I swam continuously from start to finish. I do a flip turn between lengths.
Has anyone had similar (or good) results swimming with the Charge 3? If this is normal then I may have to return it.
10-14-2018 17:34
10-14-2018 17:34
10-15-2018 11:56
10-15-2018 11:56
10-16-2018 09:22
10-16-2018 09:22
I've been communicating with Fitbit customer service on this issue as well. Here is their latest response:
10-16-2018 09:39 - edited 10-16-2018 10:39
Thank you for doing that, we all likely should have started at that point,
but the answer indicates that the result may have been the same in this
case. It's kind of weird as you'd thing that something like this and
especially the date thing could be relatively easily fixed via a sw update.
Anyway, I got it and likely won't return. Though underwhelming based on the
swimming expectations conveyed, it is nice that I can simply leave it on on
the water at minimum...
Kind regards,
10-16-2018 09:57
10-16-2018 09:57
@Rjgits Is there any other bug or issue you are experiencing with your charge 3? I am curious to know.
Best Answer10-16-2018 10:38
10-16-2018 10:38
10-16-2018 10:50
10-16-2018 10:50
I've also had the screen default to some unexpected screen while swimming. I assumed it was because the water was messing with the touch screen or touch button somehow.
10-16-2018 10:51
10-16-2018 10:51
10-17-2018 12:25
10-17-2018 12:25
- It gives 3 different burned calories on the same training (2km Swim in 1h) :95/326/856
- It counts way to many steps and stairs.
- I cycle without bicycle
- i doesnt sync
- i hope It crashes so I can buy another brand.
- First and last Fitbit EVER
10-17-2018 13:13
10-17-2018 13:13
Hi, excitedly opened my new charge 3 today bought specifically because I love swimming. I was really disappointed to find that it will not show a heart rate reading in the water as want to know how much cardio I achieve.
So I took it for its first swim and afterwards checked the synced data on my phone. it firstly said I'd used 77 calories which was ludicrous as I swam 84 lengths in an hour. However it did successfully log the right no. of lengths maybe because my movement happens to work with the tracker after each length as mentioned on here. I will try again tomorrow....but if it is not worth the upgrade & if I end up manually logging my swims still... If my rush to get the charge 3 is pointless then i may return it :(((
10-17-2018 13:21
10-17-2018 13:21
Right I'll try that tomoro, used manual for first time with new charge 3 today and wondered if the auto track might leave the heart rate monitor on because it definitely picked up in the shower once I'd finished.
I used to tape up my old charge hr and take it swimming and it would give me heart rate data for about a year until it finally died haha! It was hit and miss but better if quite tightly done up.
Best Answer10-17-2018 13:43
10-17-2018 13:43
Can you describe the technique you use that you think is registering the lap changes on the Charge 3? I still have not been able to get it to work consistently. Now it's not even auto tracking my swims so I have to add the record in manually afterward. Do you push off the wall hard on your turns? I intentionally don't but maybe I'll try that tomorrow.
Best Answer10-17-2018 13:57
10-17-2018 13:57
Hi you know what it's like it's quite hard to think through what one does but I always tend to reach forward face down with one hand just before the end of the length while I twist almost face up as I touch the end and yes, feet swing behind & push hard to propel myself forward into the next length momentariy making the most of the thrust before the stroke! If that makes any sense & I may have a disaster tomorrow on my 2nd swim lol!! Will report back 😄
10-17-2018 14:04
10-17-2018 14:04
I swam 64 lengths the other day and it recorded 62 which I thought wasn’t too bad for accuracy. I did it on the manual setting.
10-18-2018 14:04
10-18-2018 14:04
Swam 70 lengths tonight and the auto track picked up swimming with correct timing and distance exactly... However it also logged crazy calorie usage as 131 cals. So I have still ended up logging the swim to make it correct!! It does not make sense when energy use is totally disconnected to timing and distance covered???
Maybe a good wall push does help.
There is vague heart rate data on auto but it is not correct!
Best Answer10-18-2018 14:19
10-18-2018 14:19
I went swimming again this morning, and this time with every turn I made sure to push off the wall very hard. I was using the auto tracking feature though, and when I finished the Charge 3 had not auto tracked anything. Next time I'll try a manual swim session and see if it detects my turns that way.
Best Answer10-18-2018 22:37
10-18-2018 22:37
Mine is accurate as far as laps but way off on calories burned I have contacted Fitbit but not much else Fairly frustrating because I was told how much better it was than the swim watch I was using. The other watch is limited but it does work correctly just bulky. I do like other features on Fitbit.
Best Answer10-19-2018 03:43
10-19-2018 03:43
That is crazy, it should track something with all the arm movement at least!
Best Answer10-19-2018 03:48
10-19-2018 03:48
Alas, I think all us swimmers expected so much more but swimming aside, as a general tracker it is a good rounder!
Best Answer10-19-2018 04:06
10-19-2018 04:06
I had the fitbit versa before the charge 3 and I would recommend the versa it was perfect at counting lengths. The charge 3 is rubbish.
