05-18-2020
03:12
09:40
05-18-2020
03:12
09:40
Since my iPhone updated I have not been able to sync my Charge 2. I have an old iPhone that hadn’t been updated and it syncs fine on that so assume there is a change preventing the Bluetooth connecting.
The fitbit is working fine and all other Bluetooth devices connect. Will Fitbit be issuing a patch to update
05-18-2020 03:33
05-18-2020 03:33
Hi, and welcome to the Community!
I assume the update you refer to is 13.4.1
If so, then there is a known issue that Fitbit are working on. Keep an eye on the following thread where they are posting updates and suggestions:
https://community.fitbit.com/t5/iOS-App/Issues-syncing-after-updating-to-13-4-1/td-p/4240953
05-18-2020 03:43
05-18-2020 03:43
I'm having real issues with syncing since the weekend, no device found on the fitbit app on my iPhone and iPad it just won't connect/sync!
05-18-2020 03:46
05-18-2020 03:46
@NSW43 if your devices were just updated to 13.4.1 then check out the thread I link to in my previous post.
If not, then the usual things I try when I get syncing issues are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
05-18-2020 07:04
05-18-2020 07:04
Thanks for your reply and help, I have tried all of that and I do have the latest update on my iPhone, hopefully it will be resolved soon! 🙂
