07-11-2019
11:55
14:54
07-11-2019
11:55
14:54
Recent change to Android 6.0 requires Location be open to all apps. Totally unacceptable, all apps should not have access to my location. Chat at Fit bit not any help.
07-11-2019 11:59
07-11-2019 11:59
As you say, this was a requirement introduced with Android 6 - by Google. Fitbit have no option but to comply if they are to sync over bluetooth. See: Help article: Why is the Fitbit app prompting me to turn on location services?
You may be unhappy about it but you need to be unhappy with google
07-11-2019 12:36
07-11-2019 12:36
Best Answer07-12-2019 09:52
07-12-2019 09:52
Steve, I am unable to manually synch my Charge2 as I do not know how to do so! I am not finding any info on how to manually synch either. Other people are mentioning changes to the software requiring location details. I do not have the app on my phone (it is too old to run the stuff it already has on it well!) and I synch on my home laptop and my work desktop. My work desktop was configured in another part of the country so if they get location info it will be a thousand+ miles off. My home laptop for some reason is also not synching. This is since Wednesday of this week. Please guide me to instructions or resolution if you can! Thank-you!
Best Answer07-12-2019 10:34
07-12-2019 10:34
@jschafer the location services discussed in this thread relate to android mobile devices so are not a concern for your laptop or desktop.
The usual things to try when you get syncing issues are:
Good luck!
Best Answer07-12-2019 10:40
07-12-2019 10:40
