12-28-2019 13:14 - last edited on 09-08-2020 11:28 by
I can't get my old fitbit (which I haven't used for a while because it stopped working properly) to sync. I have tried the help options but nothing seems to work. Am syncing to the app on a chromebook. A message on the top says I haven't synced since April 2017 and has the pink sync icon but with a line through. Any ideas? (why isn't there a nice obvious "click here to sync" button!
12-28-2019 14:16
12-28-2019 14:16
I'm not sure of this, but:
I have read Chromebooks are not officially supported by Fitbit. Some people say it can be done but depends on the particular Chromebook model. Others mention workarounds to get it going.
So that might be your problem. If you have any other device to even just give it a try, that might tell you if Chromebook is indeed your issue.
12-29-2019 02:16
12-29-2019 02:16
