10-25-2019
06:09
12:06
10-25-2019
06:09
12:06
Recently I have been unable to get my Fitbit to display the correct time. It's 8 hours behind. When I checked the location under Advance Settings is says Los Angeles although I am in London. My iPhone displays the correct time, my location on the iPhone is London but for some reason the fitly app thinks I am in Los Angeles. I have tried manually setting it to London but it changes back to Los Angeles. I have tried deleting app and reinstalling but same thing happened. HELP please - need a fix ....
10-25-2019 07:41
10-25-2019 07:41
Both of you, try this. Go to Fitbit.com Dashboard and click on Gear Icon at upper right and then Settings. Set Time Zone manually and scroll down to click on Submit and then sync your tracker.
10-25-2019 06:59
10-25-2019 06:59
Hi Graham,
I'm having the same problem. I've tried everything to fix it and so far no luck. Unfortunately, Fitbit's customer service is not the best. Hope one of us figures it out soon. I've travelled extensively and this is the first time this has happened.
Best Answer10-25-2019 07:41
10-25-2019 07:41
10-26-2019 07:01
10-26-2019 07:01
Thanks! I finally got hold of customer support and they walked me through it.
Best Answer04-02-2020 23:30
04-02-2020 23:30
Thank you SO much. This was driving me nuts as I was trying to change
it in the app, and I could see it going back to the default (not my time zone).
