Time Zone Won't Change
ANSWERED
Just returned from vacation. Synched phone and Fitbit multiple times. Correct time zone will not appear. Never had this problem before. Can someone help?
1 BEST ANSWER
Accepted Solutions
Go to Fitbit.com and click on the gear icon at the upper right and then Settings.  Scroll down to Time zone and set it correctly.  Then scroll on down and click on Submit and then sync your tracker.
6 REPLIES 6
This used to change automatically when you sync in a new time zone. Did Fitbit actually take functionality AWAY??
Gary Bloom
Update: Thanks for instructions on how to manually change time zone. After a full 24 hours in my new time zone, the Fitbit finally changed it automatically. There must be a technical issue, as time zone should have changed when synched with my phone. ... But, now I know how to do this manually, thanks to post below.
Worked on older models but not on my current Charge 3
Thank you so much. It switched a week ago when I went into a new time zone, but didn’t switch back when I returned 4 days later. I have been manually syncing it with the app for days now. Who knew the website was the trick. Thank you!
Hello everyone. @jjp4 Nice to see you around.
It's great to hear that the instructions shared in this thread helped to resolve the inconvenience and I hope you can continue tracking towards your fitness goals.
In addition, I'd like to let you know that this thread is now closed. If you have additional questions or inquiries, please post them in a new thread and in the correct board.
See you around.
Wilson M. | Community Moderator, Fitbit.
