11-30-2019
18:01
11:42
11-30-2019
18:01
11:42
I have no idea how to set the proper date and time. Please help.
12-01-2019 05:09
12-01-2019 05:09
You can't manually set the time but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the timezone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
