02-04-2020
07:55
10:23
02-04-2020
07:55
10:23
I wear my tracker while using my treadmill. Should I manually log my time after I am finished?
Seems like the manual log adds steps. If I manually log is this double counting the steps?
02-04-2020 11:24
02-04-2020 11:24
There's no reason to manually log it afterward. If it doesn't auto-recognize it, use the Exercise App to tell it when you are starting and stopping the workout.
Best Answer02-04-2020 12:27
02-04-2020 12:27
Instructions on adding treadmill are found here.
Best Answer02-05-2020 08:06
02-05-2020 08:06
Thanks for the reply. I don't think my Charge 2 supports the Exercise App, but I did set up my tracker to auto recognize walks and runs.
Thanks again.
Best Answer02-05-2020 08:08
02-05-2020 08:08
Thanks for the tip. Treadmill is now in my shortcuts.
