07-11-2020
04:00
09:24
07-11-2020
04:00
09:24
Hi there,
I have been using my Charge 2 for 1.6 years now and I was just given a Versa as a gift. Is is possible to transfer my existing data to my new Fitbit? I have been hesitant to transition and I can't find anything on the forum.
07-11-2020 04:32
07-11-2020 04:32
Yes, that's not problem. All your data is held on the fitbit servers so it's perfectly safe.
Do one last sync of your Charge 2 to make sure you don't lose any unsynced data. Then, on the main screen of the app select "set up a device". Choose the Versa and follow the prompts. This will add the Versa to your account and you can then choose whether to keep the Charge 2 connected (so you can swap between them) or remove the Charge 2 by selecting it from the list of devices and taking the option to delete it.
07-11-2020 07:48
07-11-2020 07:48
Best Answer07-11-2020 07:59
07-11-2020 07:59
Sorry - just reread my post and I missed a step. From the main screen in the app select your profile image at the top left. This then takes you to your profile settings where you'll see the "set up a device"
