02-13-2020
00:45
10:23
02-13-2020
00:45
10:23
Hi
I sync my Charge 2 using a Mac but tried it this morning and was unable to sync or update because my Charge 2 isn't recognising that the Mac has Bluetooth turned on.
It's saying turn on Blueooth when it's already on.
Can you help?
02-13-2020 05:34
02-13-2020 05:34
I'm having the same problem only I'm using laptop/Windows 10. Update and now nothing. I double checked my Bluetooth on laptop (on) and finally uninstalled my Charge 2, planning to reinstall. Now I'm unable to reinstall my Charge 2 because the device isn't one of the choices in the install window. I'm an idiot when it comes to this and extremely frustrated...anybody??
Best Answer02-14-2020 01:38
02-14-2020 01:38
Best Answer02-15-2020 05:15
02-15-2020 05:15
Best Answer02-15-2020 13:07
02-15-2020 13:07
I had the same issue beginning last night. Fitbit support was unable to fix and offered me a 25% "discount to purchase a new device. Imagine my surprise to find that the "discount" was more expensive than the current sale on the website! Very disappointed. Not sure what to do about this.
Best Answer02-15-2020 13:32
02-15-2020 13:32
Best Answer02-15-2020 15:16
02-15-2020 15:16
There was a major fitbit snafu yesterday. I could not sync my Charge 2 from about 3 PM CST. But now it is working again. This may not be related to your problems, but you might just try again now.
Best Answer02-16-2020 05:03
02-16-2020 05:03
I sync my Charge 2 to my Samsung S6, and has worked fine for last 3 years. Had Fitbit app update ~3 days ago, now lost Bluetooth on my Fitbit device. Bluetooth on the S6 still works, which can be 'seen' by other Bluetooth devices, but nothing can 'see' the Charge 2. Like some others in this discussion, don't know what to do now because with no Bluetooth on the Charge 2, nothing can communicate with, or send software updates to, the device. Very frustrating to say the least.
Best Answer02-16-2020 12:20
02-16-2020 12:20
Best Answer02-17-2020 13:38
02-17-2020 13:38
My charge 2 no longer syncs using bluetooth. I've tried many times to connect to bluetooth, but it just won't connect. I've also reset my Charge 2. This happened after a Windows update 2 days ago. I'm using the dongle to sync now. I'm not happy about this since the dongle seems to work sporadically.
Best Answer02-18-2020 00:45
02-18-2020 00:45
I am having the same issue! My charge 2 wont sync with the Fitbit App on my Huawei, or update the tracker software. I have uninstalled the app twice now with no success, checked bluetooth and location settings and still nothing. This has been happening since I updated my Charge 2 tracker back in November 2019!!!!
Best Answer02-18-2020 04:07
02-18-2020 04:07
02-18-2020 04:52
02-18-2020 04:52
Glad I'm not the only one struggling! But to spend our hard earned cash on something then it doesn't work is ridiculous! Not everyone can afford the brand new model of Fitbit!!
Best Answer02-18-2020 05:21
02-18-2020 05:21
Best Answer02-19-2020 03:43
02-19-2020 03:43
Best Answer02-19-2020 06:16
02-19-2020 06:16
Best Answer02-19-2020 09:20
02-19-2020 09:20
Best Answer02-19-2020 10:25
02-19-2020 10:25
Didn't you lose all your past data by uninstalling and really installing the app?
Best Answer02-20-2020 01:34
02-20-2020 01:34
Best Answer02-20-2020 02:36
