01-02-2022
23:58
17:21
AndreaFitbit
01-02-2022
23:58
17:21
AndreaFitbit
Hello
I have a problem with my fitbit charge 3 SE, and smart lock feature of my phone (Xiaomi Mi MIX 2, MIUI 12 based on Android 9). I click on "unlock by Bluetooth device", enter my passcode, then I choose my paired fitbit and the phone tells me to "confirm on the band" to continue, but I don't know where to confirm because it's not showing anything special on the band.
Moderator edit: format.
01-07-2022
17:25
10:29
01-07-2022
17:25
10:29
Welcome to the Fitbit Community, @kamilskrzypek4. Thank you for sharing the message you get to unlock your phone.
Your Charge 3 doesn't have the ability to do what you're asking for. That's why you don't get anything special on the band. Were you able to unlock your phone without the band?
Keep on visiting the forums.
Best AnswerOf course I can unlock my phone without the band - by PIN/Pattern/Fingerprint but I want to unlock it without using mentioned options, automaticly when the phone is close to band. For example it works in Xiaomi Mi Band.
If you say that Charge 3 doesn't have the ability to unlock then why this is the only device that I can choose from my bluetooth device list in the options?
14:50
10:30
01-10-2022
14:50
10:30
Thanks for getting back to us and for the clarification @kamilskrzypek4.
Your Charge 3 doesn't have the requested option, I don't know why is only device you can choose from your Bluetooth list.
Best AnswerAll right, but will this be accessible someday by system update? Or this device is EOL and there will be no updates?
04:08
10:25
01-11-2022
04:08
10:25
Thank you for getting back to us and for your question @kamilskrzypek4.
I don't have information about what you asked but you can add your idea to our Suggestions.
