07-20-2016
04:51
20:15
07-20-2016
04:51
20:15
Hello,
My Fitbit Charge HR has become water damaged. it wont turn on, I have tried leaving it in rice for a full day but nothing is working. I have only had it a few months and was very careful when it came to getting it wet. After a day of intense training and a ton of persperation it stopped working I was aware that it was water resistant, I never went swimming with it, I took it off when I showered, so it came as a bit of a shock when it stopped working after a sweaty workout. if I send in my damaged Charge HR will Fitbit stand by their product and send me a new one, or fix my damage one.
-Lisa
07-20-2016 04:58
07-20-2016 05:03
07-20-2016 05:03
Of course, this is assuming that your suspicion that this is caused by water damage is correct. Could it just be a coincidence? It might be worth trying the restart a few times - it does no harm and can sort out all sorts of issues. Here's how:
https://help.fitbit.com/articles/en_US/Help_article/1186/
07-20-2016 08:56
07-20-2016 08:56
07-27-2016 05:35
07-27-2016 05:35
Welcome to the Fitbit family @LisaP923! I hope you're doing great!
If you have already tried the suggestions that @SteveH mentioned and the issue persists the issue might be that your tracker was in contact with water, try the following troubleshooting steps:
If your tracker still unresponsive contact the Support Team so they can review your device history and give you the options.
Catch you later!
07-27-2016 06:02
07-27-2016 06:02
@LisaP923 as well as the other helpful advice, instead of rice try the silicone packets that come with any vitamins etc -- they are good at sucking water out. put in a pyrex with the watch and seal it -- it may work.
11-25-2019 08:50
11-25-2019 08:50
Hi,
Did you get a response to this? I was hunting yesterday and doing drives through the woods are a lot of hard work (1st day of hunting I had 20,000 steps in) so I sweat a lot. My fitbit stopped working in a drive yesterday and I see water in the little window of the tracker part that touches your wrist. Aren't they supposed to be able to get sweaty?? Please let me know if they did anything for you. I am pretty upset. lol
11-25-2019 09:17
11-25-2019 09:17
Hi this did happen a few years ago, however they sent me a new one after this post they were really helpful
01-19-2020 10:27
01-19-2020 10:27
Did anyone reply to this or help you? I have had the same problem
01-28-2020 18:41
01-28-2020 18:41
I think I have the same problem. I wore mine swimming but it’s supposed to be water proof! It turns on and all but the screen doesn’t react when u touch it. I’ve tried almost everything and the company won’t do anything about it. It’s sad that it didn’t even last me 2 years 😞
02-04-2020 13:40
02-04-2020 13:40
it is not waterproof it's sweat proof
10-11-2020 11:00
10-11-2020 11:00
Not true. I accidentally went swimming in a pool with my fitbit inspire hr on, and it was okay.
11-08-2020 12:34 - edited 11-09-2020 10:48
The Fitbit inspire HR says "swimproof" on the box. - EDIT: 2 issues with this thread. 1) a Google for "Fitbit Inspire HR water in watch face" brings one to this thread. 2) an attempt to reply to a specific user, like Cora last month by simply hitting reply on my browser, doesn't tag Cora but may alert other users. I assume you all know which device you're using and if it is water proof or not. And you can probably choose to mute the notifications that may be sent to you externally.
11-09-2020 07:40
11-09-2020 07:40
The Charge HR is NOT waterproof. You can wash your hands wearing it but you can't swim or shower as it's not sealed and you'll easily short it out unless you're super crafty with glue (yes, I've seen this done but haven't performed a procedure like this myself). Your tracker is probably dead. You can sometimes find Charge HR "brains" (the components and circuitry to drop into your band) for $10 on eBay. You'll just need super small TORX and Phillips heads (Charge uses both) to transfer. Cheers!
11-09-2020 07:41
11-09-2020 07:41
@CoraV. yes, Inspire can be used for swimming. This is the Charge forum and Charge isn't waterproofed.
11-09-2020 07:41
11-09-2020 07:41
@johsy correct, Inspire can be used for swimming. Charge (the forum we're chatting in) isn't waterproof whatsoever.
11-09-2020 07:48
11-09-2020 07:48
This post is literally from five years ago.... they sent me a new one at the time which agin was 5 years ago
06-05-2021 22:20
06-05-2021 22:20
Hi I have a Fitbit that has Alexa so if I hold the button for a couple of seconds Alexa turns on so what do I do
