11-16-2017
11:12
18:54
11-16-2017
11:12
18:54
I have the Charge 2 and would like there to be a waterproof case for it.
Rather than a completely separate tracker, however, I would rather there be a plastic-like cover for the face of the watch.
Now, I understand that the display may be altered, but I believe that just getting the credit for steps, stairs and calories would be sufficient. Even without being able to read the display, I would still have the opportunity to obtain credit for the steps I earned.
I've seen a lot of people who are also eager for something similar, and think this would be very beneficial for all Charge 2 users.
It would likely be a cheap solution for the Charge 2's one large problem.
https://www.amazon.com/dp/B01MDN5IHN/ref=twister_B01MYTD0F4?_encoding=UTF8&psc=1
I found this on amazon, but it didn't seem to be tested for waterproof enough for me to trust it. I think if Fit bit is able to make something similar to this, I would trust it more than at amazon.
What I had in mind did not have a band, due to its price likely going much higher than people may want to spend, but I think even then, having an expensive option is greater than no options.
11-16-2017 15:08
11-16-2017 15:08
@EthanA, a search of this forum finds several posts on this same subject that might provide some helpful information to you. A couple of them are here:
https://community.fitbit.com/t5/Charge-2/Waterproof-case-for-Charge-2/m-p/2125681#M68693
https://community.fitbit.com/t5/Charge-2/Waterproofed-Fitbit-Charge-2/m-p/2018421#M54614
Best Answer01-15-2018 04:23
01-15-2018 04:23
I would also love something to enable me to swim in my charge 2
01-05-2019 14:20
01-05-2019 14:20
Hi, does anyone know if a waterproof case or similar exists for the charge 2? I don’t really want to buy a brand new tracker until this one decides to knack up completely.
