12-30-2019 16:05 - last edited on 09-08-2020 11:28 by
a, Does Fitbit use the weight recorded in calculating calories used?
b. Obviously Fitbit does not automatically change the user's weight, because my weight is shown as 186.9 lbs, unchanged from when I entered my data several years ago.
c. How can I manually change the weight?
d. Can I change from lbs to kg? It is strange because I entered it as 85 kg and also distances are reported in km.
Rod
12-30-2019 17:12
12-30-2019 17:12
You enter your current weight in the App by clicking on the weight tile and then Today and enter weight. Click on the check mark at the bottom of the screen and then sync your tracker.
You select units of measure at Fitbit.com Settings.
Best Answer12-30-2019 17:12
12-30-2019 17:12
Best Answer12-30-2019 18:50
12-30-2019 18:50
