11-28-2018
19:14
14:34
11-28-2018
19:14
14:34
What exactly does the Screen Wake feature mean on the Fitbit Charge 3? I don't see an explanation of it in the online manual or in general online forums.
'Screen Wake' means turning on the display when you turn your wrist.
11-29-2018
07:07
04:53
11-29-2018
07:07
04:53
Hey @Shefit1, welcome to the Community and @JohnnyRow thanks for the input.
I appreciate the time you took in order to find this information and am glad to see here that our friend replied your screen wake inquiry. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping! ![]()
Best AnswerHello,
i’m having difficulty with my Fitbit in the pool. Frequently when I have finished and want to pause my session the screen wake notifications screen appears. Then it doesn’t go away no matter what I do. Meanwhile the time of my session continues to run ruining my record of the swim. Is there some way of fixing this problem?
Best AnswerThe button is quite sensitive and if you long hold it it always goes to the settings options. It takes a bit of practice but try pressing for a very short time. Do not hold the bottom on. It is fiddly at first. But you can get the feeling for activating quite quickly which will take you to the pause screen.
Best AnswerThx for your reply. I’ve practiced for a bit and hope to avoid this notification screen problem in the future.
Best AnswerI just recharged my Charge 3 for the first time and my screen shows Screen Wake and Notifications
How do I get back to seeing steps and other tracking data?
Thanks
Best AnswerOk it just came back...after about 10 minutes. Any way to get regular screen back faster?
Best AnswerYou get that screen if you press and hold the side button. Just press the side button once to return to the main screen.
Best AnswerIf Screen Wake is Auto and Sleep mode is enabled, which wins? I turn my wrist when I sleep.
